  #31
Old 04-30-2020, 07:16 AM
SATAUS SATAUS is offline
MetalShaper of the Month July 2010, Dec 2011, Nov 2014, Feb 2016, March 2021
Very nice work. Very unique panel clamps too.
Thanks Marcus.
Scott
Old 08-14-2020, 06:46 AM
Default rear cab fix
Removing dent before progressing on to other parts.
Scott
Old 08-14-2020, 06:55 AM
Default side cab bead
Putting L/H and R/H side bead corners in.
Nearly ready to weld in.
Scott
Old 08-14-2020, 07:14 AM
Default bead fix
I made the L/H and R/H side bead corners many years ago, unfortunately they were a bit short and I had to extend them a small amount.
This is how I went about it.
Sanding back of weld off so the dolly has a flat surface
to sit on.
Sand the top of the welds off on the front face.
Planish weld
File weld down.
After 1st file finding high spots
More planishing
On to sanding when happy with planishing ans filing.
After sanding.
After fine sand paper.
How back of weld looks after planishing.
Ready to go into the cab corner.
Here is a link to how I made the beads/swage for the cab corners,
bloody hell it was 10 years ago :-(
http://allmetalshaping.com/showthread.php?t=1432
Scott
Old 08-14-2020, 09:29 AM
Excellent details and pics. Great result.
Thanks.
Old 08-14-2020, 09:17 PM
Lovely work Scott and thank you for showing how you did things,
Cheers Charlie
Old 08-15-2020, 07:24 PM
Great posts there Scott. Very nice work.
Old 01-06-2021, 06:02 AM
Default rear cab panel fix/replace and weld roof back on.
Sorry about the pictures that are side ways I can not get them to go in the correct way no matter what I do, if admin would like to rotate them the correct way please go for it.
creating the curve for the Pullmax to follow when putting rear swage in.
Scott
Old 01-06-2021, 06:13 AM
That is some impressive work Scott.
Thanks for sharing.
For photos: do you save them on your computer?
I know that for WIN10, to rotate them permanently, one has to keep them in a folder. Rotate the pic when it's open, then close the pic, and then close the folder. Open the folder and it will be in it's new orientation.
Old 01-06-2021, 06:27 AM
Thanks for sharing.
Hi Pugsy,
Thanks for the complement.
Yes I do keep them in a folder on my computer and they are the correct way around before I
transfer them to AllMetalshaping, once I move them over some of the pictures rotate and some
don't I have even tried to rotate the pictures the incorrect way and save them to see if they
would come out the correct way when I put them in a folder on AllMetalshaping.
Scott
