  #41
Old 01-09-2019, 08:38 AM
Like he said above- some very good tricks/techniques. Thanks for posting them, Robert. Looks great.
Old 01-09-2019, 10:09 PM
pplace's Avatar
pplace pplace is offline
That console is really coming out nicely.
I made a set of very similar dies for rivnuts as well (different sizes for different size nuts obviously) I found I needed to actually start with a smaller diameter drilled hole since it wanted to “stretch out” once dimpled. Some of the rivnuts have such small shoulders on them. Also once “squeezed” I liked the tighter fit for it to grip to. It doesn’t appear you had that issue with yours though.
Here’s a post from my ‘52 Dodge build showing how I utilized them.
Originally Posted by pplace View Post
Nothing too serious here, but thought I'd show how I had to change the cowl sides in order to blend nicer into the door jambs I made earlier.
I had cut a fair amount out of the cowl side earlier in order to have room to add the inner door jamb structure and skin.
In this picture you can also see the cowl end of the horizontal support bars that come from the radiator support. These bolt through the cowl and into a cross bar in the cab that some interior components were mounted on.
Attachment 44771
New side panel fit and welded into the door jamb. The toe board also flows down the jamb edge a bit also.
If you look close you can see the I dimpled the jamb and so the nutserts that the fender edge bolts to are flush with the surface.
Attachment 44772
This is a close up of the angled "step" on the cowl. The top of the fender has the same angle and that nests into place when bolted on. Also a slightly better view of the flush mount nutsert.
Attachment 44773
Dane
Old 01-10-2019, 03:53 AM
touringgarage touringgarage is offline
MetalShaper of the Month September 2014, April 2019
Very very nice Work !
Bernhard
