  #751
Old 10-25-2017, 09:38 PM
I spent most of the day getting the windshield frame adjusted and back in the car. All is good so I welded it in. There's still a lot of work to be done on it but it's in the right place, the windshield fits right, and it's sturdy. I have the convertible top latches but I don't know exactly where they'll land on the windshield frame so I won't cut holes for them yet. Same with the visors and rear view mirror.
I really like the look. It was well worth the effort to swap windshields.
Old 10-26-2017, 04:45 AM
Sweet.
The transition from square to rectangle is really well done.
Old 10-26-2017, 08:01 AM
I really like that glass frame. Looks like it belongs there, not an after thought!
Thanks for taking the time to share your project with us.
Old 10-26-2017, 08:53 AM
blue62 blue62 is online now
You get more done in a day then I do in month.
always look forward to your posts.
I learn something from each of them.
Dave Bradbury
Old 10-27-2017, 12:46 PM
I agree, that windshield looks perfect for your car! Nicely done!
Thanks for showing!
Old 10-29-2017, 08:10 PM
I started making bolsters for the windshield overhang in the door jamb. I originally intended to hammer form these so I cut a couple forms and started the first piece. I wasn't seeing what I wanted so I decided to do them on the bead roller and shrinker. Much better.
I tacked in the inboard panel on the left side and went on to make the outboard panel. You can also see that I started adding the 1" flanges that the windshield will mount to. I am flush mounting the windshield rather than using the original style rubber weather seal.
The outboard panel needed a little trimming but eventually fit up well so I tacked it in, checked everything out and welded it all up. The masking tape in front of the frame is just a cutting pattern for the sheet metal that will close off the cowl where I cut it. I can't go any further with that until I have the firewall from the donor car.
I need to notch the door to clear the bolster, then it's over to the right side to finish that off.
Old 11-03-2017, 08:49 PM
I made the door post out of 1 x 1 square tube. It needed a slight bend in the upper third of the exposed area to match the bend in the A pillar. Since I will be using flat glass for side windows, the run channel will have to be straight. I will weld the run channel to the door post when I'm a little further along. I want the door latch and striker in place and the door adjusted before I do that. For now, the post fits, it's adjustable, and it lines up with the A pillar.
I found some windshield trim from a 58 Olds that will work. It is wider than I need but it can easily be cut to fit.
Next I repeated the process on the right door jamb and bolster. I also finished the windshield mounting flange.
Old 11-06-2017, 02:36 PM
Door handles. I used some 1 x 2 x .065 rectangle tube to make the cases. A little overkill but I don't want any problems later. Cut, bend, drill weld, etc. I'm using some nylon bushings between the handle and the pivot pin. I can't weld these in yet but I needed to know how they'd look and if they'll fit and function.
That was a day's work. They fit in the space where I wanted them. It's tight in there because I cut into the door frame to clear the windshield frame. Anyway, I like them. They'll be painted black along with the body. Almost invisible.
Old 11-07-2017, 07:50 AM
Cool stuff Jack!
Old 11-07-2017, 09:07 AM
Nice idea for the door latch. Really like your windshield frame.
Will you be installing glass with rubber seal or urethane?
