  #31
Old 05-04-2015, 05:37 AM
elavir elavir is offline
MetalShaper of the Month May '17
Originally Posted by Stretch View Post
Richard, o/a is always my first choice on body panels due to the fact that it is much less prone to cracking and is much more malleable. As you say, if you don't use any filler rod you can end up with an invisible weld once planished. For that reason, I never add filler rod to butt welds on body panels. There really is no need.
However, for tanks and the like, tig is the perfect choice. It is infinitely more controllable and gives you that 'stacked dime look' that everyone desires these days. Although I must add, you are far more likely to get pin holes with tig...
Matt(Stretch), what do you mean by getting pin holes in a tig weld? That a tig weld can be porous?
Old 05-08-2015, 03:29 AM
Stretch Stretch is offline
MetalShaper of the Month Aug 2016, Feb 2017, Sept 2018, Dec 2020, Aug 2022
Elavir... With Tig you have to be clinically clean. Any small deposits of dirt - particularly anything carbon based - can be 'picked up' in the weld flow causing a pinhole. Ali castings are a bugger for dishing up 'buried' dirt. The golden rule is if you see any black forming in the puddle, stop welding and remove the contamination with a stainless wire brush. Snip about a 1/4 of an inch off your filler rod also, as it's likely to be contaminated.
Matt Keene
www.air-Kraft.com
Old 05-08-2015, 08:33 AM
Matt and Richard, thanks for all the advice.
Old 05-08-2015, 12:00 PM
AllyBill AllyBill is offline
I always keep one of these to hand just to be sure on anything that contains fluids or pressure or both.
https://www.pegasusautoracing.com/pr...asp?RecID=1207
Here to learn.
William Pointer
Old 05-10-2015, 03:57 AM
Oldnek Oldnek is offline
Lovely bit of kit, those welds are pretty nice.
Just a question, Its it used for cooling the fuel or other. ( Header Tank and Ice Shelf)
EK Holden V8
Old 05-10-2015, 12:01 PM
Hi John. It's used for ice and water to circulate through a chargecooler on a turbocharged flat four engine. This gets the boosted intake temps to sub-ambient, which gains considerable bhp.
Cheers, Matt
Matt Keene
www.air-Kraft.com
Old 05-10-2015, 04:15 PM
Ahh, I can see where you honed those Tig skills Matt! Very nice job on everything. Not much Dub left!
Old 05-12-2015, 05:00 AM
That's definitely a serious bit of kit............Not the everyday run of the mill Dak Dak.
Awesome bit of engineering work Matt, great job.
EK Holden V8
Old 08-01-2016, 01:04 AM
SATAUS SATAUS is offline
MetalShaper of the Month July 2010, Dec 2011, Nov 2014, Feb 2016, March 2021
Congratulations Mark on MSOTM.
Scott
Old 08-01-2016, 03:42 AM
Well done Matt! Well deserved.
