Porsche bod mod
This buggy was out on the rural roads being tested yesterday.
Attachment 56206 4 corners had steel sections removed and prototype aluminum bits made up and installed. Standard process = mock up the concept, make trial parts, make subsequent changes if and when necessary, finalize, install, adjust. And road test. MDF contour form Standard simple process - handwork, Air Hammer and shrinker, torch welding, pop-ular rivets. The "GT3" buggy bod mods are "in white" and when testing is finished, then buggy will go to paint. (Report is that all is well.)
Kent http://www.tinmantech.com "All it takes is a little practical experience to blow the he!! out of a perfectly good theory." --- Lloyd Rosenquist, charter member AWS, 1919. Last edited by crystallographic; 04-18-2020 at 02:24 PM. |
Very nice work as usual.
Whole new inner guard too I presume?
How good does that look .great work
Cheers Paul
Paul |
very nice 'buggy'. Beats a $500 paddock basher anyday
Rick Jones |
Beautiful work. I would need a similar job.
Will the inner wheel arch be closed?
Jaroslav |
Wow! That car looks the business!
How did you do the joggle on the remains of the original fender, on the car?
Mike K |
Verry nice work. And the car......
Onorius |
Lovely work there, Kent. Did you weld the fenders on or are they removable so they can be replaced in an accident?
Manny Remember that the best of men, are only men at best. |
Porsche bod mod
Manny, re-read the first page.
John S. E _________________________________________________ Torque is nothing, unless you can get it to the road. |
Marcus and Jaro - Thank you very much. Yes, the inner arch is also made and pieced in, back together. Arches join for complete original strength - adult can sit on the corners. No extra tube framing added, back to original type of closure/edge joint at the arch.
Paul - Thank you! Mike K. - Thank you! used a handheld pneumatic squeezer with dies machined to match the offset required. Efficient, easy, accurate. Onorius - Thank you! Manny - Thank you! this job is what is known as "bonded structure" in industry. Fit, drilled, cleaned, 20-min cure goop applied and riveted wet. Sorta permanent parts when joined. Car is unit-body so any cut-away areas have to be thought out for strength, handling, function. Test results: Car runs a bit faster, handles noticeably better, seems lighter. Very worthwhile bod mod. Will test on speedway, next.
