Old 03-09-2010, 06:21 AM
LooseDuece's Avatar
LooseDuece LooseDuece is offline
Default O/A ali pic's
Some of my latest trial welding pic's.
The weld seems to be dirty yet I have cleaned and fluxed the rod and area well ?
In most welding vid's I see the welder keep the torch into it.
I find i have to take it away or a blow through will occur.
I've adjusted the flame, tip and regulator settings.
In last pic I can still achieve a nice result after joining the 2 pieces, but the time taken is much more than if laying a proper flat neat bead.
Old 03-10-2010, 02:26 AM
Originally Posted by german8rcoupe View Post
I was surprised and pleased to see in that Kent White vid that he starts by blowing holes at one end! That's what I do!
Practise,practise....
Put yout first tack about three quarters of an inch in from the edge and you wil not have this problem.
Old 03-10-2010, 11:52 AM
kjc kjc is offline
David,
I suspect the tip sizes 1,2,3,5,7 etc relate to the gas consumption in cu-ft/hr of the rig with that tip. Bigger number = larger hole and thus higher gas consumption.
I believe the only reliable way to compare different manufacturers tips is either by drill size (of the hole) or consumption. 00, aw202, #5 etc are all pretty meaningless.
For example, I use an aw202 tip in my Smith Airline for 19ga steel and it is a #69 drill size and 3cfh consumption.
ken
Old 03-10-2010, 02:54 PM
here is a guy that has collected and put together in a chart a lot of tip sizes of several brands and their orfice size.
http://bikesmithdesign.com/Welding/Tips.html
The Rod Doctor,
Richard Crees
Old 03-10-2010, 04:06 PM
Ken, that is the only info you will get on the tips here. We have guides that tell you what tip size to use for what material so its all you need.
Of course it does not help if you want to compare our tips to those from another country.
Richard, The link would not work for me.
Old 03-10-2010, 04:51 PM
Welding Tip Size Comparison Chart
Click here to download an Excel file with this info.
If you have info on any other torches/tips, please let me know at Mark@BikesmithDesign.com
Thanks to;
Attila Kokeny for the European manufacturers, Messer and CGE Rhona. They are not exactly the same sizes as the US tips they are aligned with, but close enough for comparison.
He also provided the Welding Thickness/Tip Size chart.
Aaron Novak supplied the #6, #7 and 1/2 size Meco Midget tip sizes.
Peter F. informs me that in Australia the big name in gas welding equip. is CIG. Their tip sizes, 6 thru 32, correspond to 0.6 to 3.2mm orifces.
Far too logical.
Welding Thickness Tip Size
Inches mm Drill
Size
Inches mm
1/64 0.38 76 0.020 0.51
1/32 0.78 72 0.025 0.64
1/16 1.59 68 0.031 0.79
3/32 2.38 62 0.038 0.96
1/8 3.18 56 0.047 1.19
3/16 4.76 54 0.055 1.40
¼ 6.35 51 0.067 1.70
5/16 7.94 48 0.076 1.93
3/8 9.53 44 0.086 2.18
½ 12.70 40 0.098 2.49
5/8 15.88 35 0.110 2.79
¾ 19.05 30 0.128 3.25
Welding vs. Brazing
High gas velocities are important when welding. So you need to match the tip size to the material/joint.
Brazing bicycle frames is different. Some builders, myself included, will build an entire frame, from fillets to braze ons, with a single, large tip. Just by varying gas flow with the valves. (Maybe using a bit more pressure than my usual 4-5psi for larger fillets.) I own every tip ever made for the Smith's AW1A , but I could get along just fine with just an AW205, which is big enough to weld 1/8" steel. Other builders get good results using a tip as small as an AW201 for braze ons.
Wire
Drill
Decimal
Inch
Smiths
AW1A
Little
Torch
Harris Victor Meco
Midget
Messer GCE
Rhona
Metric
Eqiv.
97 0.0059 #2 0.15
85 0.011 #3 0.279
80 0.0135 #00 0.343
76 0.02 AW200 #4 0 00 00 0.508
75 0.022 0 #000 0.559
74 0.0225 AW20 0 0 0.572
73 0.5 0.572
71 0.026 AW201 1 1 1 0.66
70 0.028 #00 1 0.711
69 0.0292 AW202 #5 2 2 0.742
67 0.032 AW203 1.5 0.813
65 0.035 2 0 2 0.889
63 0.037 AW204 #6 2.5 2E 0.94
60 0.04 1 1.016
58 0.042 3 3 1.067
57 0.043 AW205 1.092
Wire
Drill
Decimal
Inch
Smiths
AW1A
Little
Torch
Harris Victor Meco
Midget
Messer GCE
Rhona
Metric
Eqiv.
56 0.0465 AW206 #7 2 4 3 3 1.181
55 0.052 4 1.321
54 0.055 AW207 4.5 3.5 3E 1.397
53 0.0595 5 3 1.511
52 0.0635 AW208 5 4 4 1.613
51 0.067 6 1.702
49 0.073 AW209 4 5.5 4E 1.854
48 0.076 7 1.93
47 0.076 6 1.93
45 0.082 8 2.083
44 0.086 AW210 5 5 2.184
43 0.089 9 5 2.261
42 7 2.261
40 0.098 10 2.489
36 0.106 6 2.692
35 0.11 13 2.794
Wire
Drill
Decimal
Inch
Smiths
AW1A
Little
Torch
Harris Victor Meco
Midget
Messer GCE
Rhona
Metric
Eqiv.
does this show up David
Old 03-10-2010, 04:53 PM
by the chart it looks like the #5 that David uses is between our #00 & #000
