Hammer forming technique
Hi Guys
Just after some advice on making a number plate recess like this? The sheet metal is about 1.1mm thick. I was thinking of using a hammer forming technique but what do you guys think?? Im interested in what others have done in this situation or similar. Thanks Bart
Bart Risuccia |
Appears you are doing a LH Hatchback, very nice. I thought I spotto the makings of the Liftback door.
I would go the hammer form route.
John EK Holden V8 |
Thanks mate, LX Hatchback but close enough
This is the beaver panel I just made, not finished yet but I want the option of putting the number plate recess. I like it plain as it looks cleaner but some people want as per original with recess. Thanks Bart
Bart Risuccia |
I've recently had some luck hammer forming by using a sheet of thick rubber about 1 cm thick along with a big flat faced mallet. The rubber tends to hold the sheet along the flat surfaces as it flows down into the lower details.
Bob Don't believe everything you think. |
Thanks guys
I have tried on galvanised sheet as a test and it didnt come out too well. I will try again, im thinking of using an air hammer with brass bit or chopping board plastic bit? Ill see how i go
Bart Risuccia |
Use some cold rolled steel and you will get completely different results!
Thanks mate I certainly agree.
Only thing is when I start on the roof eventually when I get to it I cant get cold rolled in that size which is around 1340mmx1360mm but I found Blackwoods sell 1500mmx2400mm in galvanised so gal will be difficult to avoid on the big stuff.
Bart Risuccia |
Hi Bart,
I thought I'd toss in a bit of nickel knowledge on this shape: The offsets I am seeing here give me pause. The amount of step that needs to be pushed indicates (to me, at least) that you have a "draw" that might need to be addressed, to make those step-downs. I would almost be tempted to use a 5T or 10T press to shove that shape into/between some cut profiles at each end, glued and screwed to a bolster board base. The pusher can be whatever wood or pipe - but watch those offsets try to tear because of the forced reduction loads in those small areas. Lube may help - some gear oil mixed with Ivory soap flakes is good, cheap, and available. Sometimes I allow the press to move enough to get to the serious resistance level, and then I split the areas with a mini saw and shove again, making two little welded-in fillers to finish up....
For me I would worry that the draw on the sides of the lower sections would pull the rest of the panel around.
I would put 2 cuts with the fen saw at the little wedge shapes on the side. I would do the whole job in the bead roller including the folds through the middle. I am thinking the center panel will end up to long because it is taking a shorter path at the bottom, it may require a cut through left to right to remove the excess. I would put that on a fold line because it would make it easier to clean up. The wedge sections I would put in last. First things first you would need a deep bead roller. In hindsight you probabley should have done the recess earlier in the panel build. Jim
Nothing is to hard its just how much time you want to give it. Last edited by ozi jim; 02-05-2016 at 01:57 PM. |
I agree, I should have done this bit earlier, but live and learn I guess, I'm definitely learning here
This is what I got so far, not too good but I think it shows what Jim was saying about the panel turning. I feel disappointed in my self but I have to remind my self I'm learning and a beginner. I will smooth out this hammer form, excuse the rough look of it. I was thinking of putting this into my pullmax/vibro shear with male die and going for it that way. But from what you guys are saying above maybe I should not??
Bart Risuccia Last edited by Bart; 02-05-2016 at 07:58 PM. |
