QUIET Tig cooler?
Anyone have recommendations for a QUIET Tig cooler? I've got a Miller Dynasty 200 and am using an HTP ARCTIC CHILL cooler. Although it works very well, the HTP is VERY noisy. I need something quieter. No, I don't want to build my own. I need something plug-n-play.
Thanks!
Quieter
Bill,
Most of the coolers I've run into do create quite a bit of fan noise. I've known a couple people that circulate the water from a large container, with no fan. The volume of water is enough that it heats up slowly. I've also seen a few that just hook up to the fresh water supply. But that means you're paying for water that goes to waste. I guess you could run it into a rain barrel, and use it later.
John Ron Covell, Autofuturist books (Tim Barton/Bill Longyard) and Kent White metalshaping DVD's available, shipped from the US. Contact lane@mountainhouseestate.com for price and availability. |
I have a small Bernard 2500SS on my small Miller 180SD TIG and it's very quiet. The nominal pump hum is as loud or louder than the fan. The overall cooler noise is equivalent to the fan on the welder. Don't think this specific cooler is still sold new. Seems to work fine for me, although I've often thought of making a larger tank for it.
Fan noise trivia- As a teenager going through major overheating issues with my first purchased car (67 Mustang) a variety of fans were tried. I quickly learned that fan noise has a strong relationship to blade pitch- the steeper the pitch, the greater the noise especially as speed increases. Greater pitch/noise also seemed to have a measurable negative impact on fuel consumption. At the same time, it didn't necessarily cool the engine better. Ever since, I always wondered if there is a significant curve change in cfm and power requirements as blade pitch goes happy quiet to rough noisy. engine porting experts talk about noisy or rough air turbulence with decrease in efficiency as a port shape and air speed changes.
Do you need a cooler?
Bill,
I failed to mention, I run the Miller Dynasty 200 with an air cooled torch, as I don't get into that much thick stuff with the TIG. If you are welding thinner materials, just get an air cooled torch. I have no idea if you can run a waterer cooled torch with the water off, without damaging it.
Jeffrey Scott |
Does anyone know how much pressure drop TIG cables have?
Jerry Jackson San Antonio |
TIG cooler
I have a 2 gallon pail with a fountain pump. Can barely hear it with the welder turned off. It has worked fine for 20 years. I drop a couple freezer packs in it if I am welding at 250+ for hours. I measured the pressure drop on an old torch that was plugging. 15 psi drop. I flushed it out (lime away I think) and rinsed it good. Got it down to 5 psi. 25 foot cable. I did not measure the flow rate.
Bill Funk |
My first tig was a miller dial arc 250. Got from a factory in town. Had a stainless tank maybe 3 gallons. Pro con pump like above. No fan or radiator. Had about 30 feet of cable so 60 feet of liquid line.
They were run at 80 to 140 amps. they were used for 8 hr shifts and it worked for over 20 years before I got it. (Grainier sells them) Very quiet just the sound of the elec. motor with pump. Always use distilled water to avoid mineral build up in the system!! They told me to add a little auto water pump lube also. Steve
Noisy Cooler
Don't forget that the cooler you are using is probably designed to cool the torch at 100%. I usually use my machine on low or medium (Dialarc 250), I only have a pump, 1 gallon reservoir, no fan and no radiator. With my HW20 torch, I've never even made the water warm. Maybe you could try unplugging the fan and see if the water gets warm. The only time my cooler has gotten noisy is when the rubber in the flex drive gets worn.
http://pokiespages.com/ |
