Old 02-21-2011, 08:09 AM
fisherboys fisherboys is offline
Default test pic
Mark
Old 02-21-2011, 08:24 AM
Hi Mark,
The only thing left to do is click on the paperclip again and select the photo you want or select insert all. That's what makes them show up without having to click on the photo. You have to be in the advanced editor if you're doing it after the original attachment...that is if you are editing the post later.
We usually do that for folks but it'd be really nice if everyone would learn the last step...
Old 02-21-2011, 08:33 AM
Mark,
To make the picture show you can click on the link and the picture come up. Right click on picture and a dropdown box appears. At the bottom you will see properties. click on that, and a dropdown box will appear. At the top is location. Highlight it and copy. click edit at the bottom of the post. At the top is a tool bad. There is a yellow box with a mountain and the sun in it. Click on it and a box appears with a highlighted http:// right click on the highlighted part and paste the location that you copied from the picture. click ok and it will show up where the cursor was. The picture will show up as a location. Click save and the picture will now show.
You can do the same thing from the album. click on the thumbnail and a large picture will show. Follow the instruction above.
