#181
Nice Workmanship
Thanks for sharing. Fred26t
Fred26T |
#182
I welded the two gutter halves together and did some final adjusting and fitting.
It's good, in its exact location.
#183
I am using some 1" square tube for strength in the area where the latches for the roof will mount. I'm going all the way around, directly below where the roof seal will set on the deck. Bending it up old school. Again; primitive but effective. I just noticed I'm getting some pretty big cracks in my stump, I'll have to put some bands on that.
#184
The roof support fits pretty good. I noticed that the strip of 22 gage that I've been using to check contour sags a little between stations since I removed station #2. I have a strip of plastic that holds its shape better so I'll start using that. I still need to do a little bit more with the support but it"s very close. I ran out of energy before I ran out of work. Tomorrow"s another day.
Jack Set a Goal So Big That You Can't Achieve It Until You Grow Into The Person That Can. Last edited by Jack 1957; 12-20-2015 at 10:11 PM. |
#185
Brackets, brackets, brackets. I made these two corner braces that tie the roof support to the inner quarters. With the hole punch, If you go one size up and flip the cutting die over you can dimple the holes quick and easy.
#186
Welded the gutter and support brackets together and painted the backside.
#187
Next I bent up a center support out of 1" square tube. This will tie everything together right down the middle. I set it up on the buck one last time to check shape before cutting the buck. From this point on, this bar becomes the "buck" so its got to be dead on.. The two stations that were in this area were never mounted permanently because I knew I would be taking them in and out during this process. I'm ready to start welding everything in so they are out for good now.
Jack Set a Goal So Big That You Can't Achieve It Until You Grow Into The Person That Can. Last edited by Jack 1957; 12-22-2015 at 09:46 PM. |
#188
I started welding the right and left sides in. Not quite finished yet but it's already very strong and rigid. Almost like a roll cage. I have some welding to finish up tomorrow, then roof latches, deck lid hinges, and upper seat belt mounts.
Jack Set a Goal So Big That You Can't Achieve It Until You Grow Into The Person That Can. Last edited by Jack 1957; 12-22-2015 at 09:57 PM. |
#189
Looking good Jack. I like your simple trick with the cutting dies. Do you do the emboss first and then cut? Or first punch the hole and then flare? How do you align the holes?
Kind regards, Frank
Frank de Kleuver |
#190
Drill the pilot hole, set the larger die on upside down and scribe the circle, remove the large die and put on the smaller die. Punch the hole then put the larger die back in. If you tried to dimple first there would be too much distortion.
Jack Set a Goal So Big That You Can't Achieve It Until You Grow Into The Person That Can. Last edited by Jack 1957; 12-23-2015 at 10:38 PM. |
