Old 12-15-2015, 02:46 AM
Plymouth Dave Plymouth Dave is offline
Good work Nigel. I like the floor pans you did very impressive , I hope the repairs on the dodge turn out as good . Thanks for your help with the sill panel at the meet .
Old 12-15-2015, 03:47 AM
ekdave1962's Avatar
geez fantastic work mate
and u here worried about showing it
keep the post coming and willsee u at mm16
Geelong victoria
Australia
Old 12-15-2015, 04:39 AM
Originally Posted by Meeksie View Post
Next I wanted to replace this monstrocity.
Nigel, your floorpan is 1000 times better than the EK wagon we had, I don't why you wanted to replace it.
I glad you have been inspired to post, cause you are doing a pretty fine job.
What colour did you wake up today
Cheers John
Old 12-15-2015, 07:03 AM
Meeksie Meeksie is offline
Originally Posted by sblack View Post
Awesome work! I really like the patch panel on forward edge of the lower left rear fender that is oart of the door sill. I count 5 folds with a gentle curve and you really nailed it. How did you make that shape? Is it allows ne piece? How did you get that subtle curve in it?
Thanks for posting.
Thanks to all for the comments and your interest in the project.
Scott, the rear 1/4 patch panel is all one piece. I did make a little mistake when I trimmed the lower section and if you look hard I had to weld in a pie cut section - I misjudged the angle of the bottom when it was to be folded under.
I've learnt most things from the Peter Tommasini dvds I've purchased. I'm only learning but this is how I did the front lower cowl, the pros will no doubt be able to do it in a better way. So please let us all know how it can be done more easily.
1/ I made the template first.
2/ I wheel a little shape into the main section with my english wheel
3/ I folded the edge to 90 degrees and shrank the edge to match the door contour. Then I made a die for my Trumpf and stamped in the edges
4/ I tipped the line using the edge of my english wheel
5/ I tipped this edge over using the english wheel as well
6/ I used a blocking hammer on stump and sandbag to get the front shapes in and planished them out a little with a planishing hammer
Then I folded over the final lower edge.
The rear 1/4 panel lower patch was much the same but with no blocking. I wheel in a bit of shape, fold the front edge to 90 degrees, shrank it to fit the door contour, made a die for the trumpf and stamped in the fold lines, tipped the rear wheel arch shape in with the E wheel, folded under the bottom section.
Nigel.M
Old 12-15-2015, 07:15 AM
Cheers John
Very funny John.
Will will be glad to know that I do actually listen when you all speak. I went and got some of this UPOL stuff today. It must be better than the stuff you get in NSW as it's heaps more expensive.
I also got a couple of hammers after I saw Peter using the same ones, good news with those is the prices are still stuck in the 90s. Note where they were made - the Berlin wall came down long ago. The guy who owns the store says he has had them on the shelves 20 years and the previous owner had them 10 years. Lets hope the heads don't fly off when I start swinging them.
Nigel.M
Old 02-10-2016, 07:48 AM
So I have managed to get a bit done on the 37 the past few days.
I made a few little bits to help hold the floor in place and have partially welded it into position. I had to stop fully welding it as the material the floorpans was resting on was catching alight and making for a couple of pretty crappy welds. I'll take the body off and fully weld it all is as soon as possible.
Firstly I made a couple of panels to hold the lower cowls and firewall in place. I had to eat all the Vita Bits first though.
I made a couple of bits that go between the floorpan and the lower front of the quarter panel.
I then started on the new rocker panels. Cut them out and tipped em over in the wheel
Had to bash a bit of shape into them so they can be welded to the lower cowl and a slit to go beneath the floorpan.
More weld through primer for protection.
That's right the floorpan went back in a little higher than stock. How much I don't know as the floorpan that was in before was at a number of different levels, it's not radical though.
Made these bits to support the 'B' pillar
And that's how she currently sits, should get the body off soon and finish off the welding.
Nigel.M
Old 02-11-2016, 03:14 AM
Nice work there Nigel.
Old 02-11-2016, 06:15 AM
redoxide redoxide is offline
Looks excellent..
re the trumph tooling can you post a picture of the tooling you used to form the door shut edge. Those double steps always stump me... along with most other stuff lol..
Ian
Old 02-11-2016, 01:45 PM
doug_walter2002's Avatar
doug_walter2002 doug_walter2002 is offline
Great build, have the same car so it I quite inspiring. I will be referring back to this thread when it come time to re-do mine.
Doug Walter
Old 02-11-2016, 08:12 PM
sblack sblack is offline
Thank you for the info. I have Peter's dvds too and have learned a lot. I too would like to see the tooling you used. Keep up the good work and thank you for sharing.
Scott in Montreal
