Old 06-10-2012, 09:47 PM
Default Santa Cruz 2012 Pictures
Some (but not all) the big tools available at this fantastic event. Sorry to Lazze, these pictures were taken on Sunday so I missed his wheel, bead roller, shrinker, and other assorted goodies.
John Forbes' English Wheel
John Forbes' Pullmax
John Forbes' Box & Pan Brake
John Forbes' Kick Shrinker
John Forbes' Slip Roll
John Forbes' Niagra Shear
Old 06-10-2012, 09:51 PM
Rick Scott's Kick Shrinker
Rick Scott's Small Reciprocating Machine with Thumbnail Shrinking Dies
Rick Scott's Extra Deep Throat Bead Roller
Rick Scott's Bamm Bamm Power Hammer
Rick Scott's Mechhammer
Rick Scott's English Wheel
It has an electric dial indicator for extreme repeatability
Rick Scott's Bead Roller
Old 06-10-2012, 09:54 PM
Kent White's Air Power Hammer
Some of the dies for Kent White's Air Power Hammer
Jaysin Spaceman's Amazing English Wheel
Old 06-10-2012, 10:06 PM
One of Baileigh Industrial's 19" Power Hammers: PH-19
Big Daddy of Baileigh Industrial's 19" Power Hammers: MH-19
Baileigh Industrial's High Throat Bead Roller: BR-16E-36
Baileigh Industrial's Planishing Hammer: PH-24A
Baileigh Industrial's Pneumatic Shrinker Stretcher: MSS-14H
Baileigh Industrial's English Wheel: EW-40
Multiple upper wheels for beading and stepping on an english wheel
Nine lower wheels
Baileigh Industrial's Power Bead Roller: BR-18E-24
Baileigh Industrial's Magnetic Box and Pan Brake: BB-4816M
Old 06-10-2012, 10:08 PM
Kent White Demonstrating Gas Welding on Aluminum
Kent White straightening out some wrinkles on a fender
Ron Covell Flow Forming over a Hammerform
Ron Covell using Jaysin's English Wheel
Old 06-11-2012, 08:26 PM
Overkill Overkill is offline
Default More pics
Chris Rusch from Rusch Machine Design (RMD) showing his power hammer. Found that RMD designs and patents the yellow machines. Bailiegh Industrial is a marketing company that sells RMD products, as well as their own products. Chris helped Chris Gross make a firewall for his 26 Dodge Roadster in about an hour with the hammer on Sunday. Hopefully Chris will post some pictures.
Don Houseman and Ron Covell are building aluminum 27 T's together. This is Don's, not the one seen on Ron's buck's video, but built on the same buck.
Don holds multiple Bonneville records, and is now venturing into the stream liner and lakester classes.
Daniel Gunderson discussing the Ultra Stump and Donut Dolly with Austin.
Shane Henderson demonstrating the Bailiegh magnetic brake, including how to use a simple piece of tubing as a radius die. I noted the difference between my Magnabrake and the Bailiegh machine, is the Bailiegh has two electro magnetic rows, instead of a single one that mine Magnabrake has.
General shop photo with Rick Scott (co-host) in the white hat.
Don Houseman in the shorts and white shirt discussing Pullmax dies he's created after the Pullmax demo showing how to make a hollow wired edge (no wire) then how to use the Pullmax to set the rivets.
Old 06-11-2012, 08:40 PM
Default And even more pics
Ken C. working on his 57 Chevy parts
Hammer form/female tank buck brought by Tom.
Ron Covell's hammer form demonstration pieces.
Shane Henderson of Bailiegh doing a demo. Note the round tubing to be used as a radius die.
Jaysin and Mrs. Carbol with Kevin Lewis, looking at the Ferrari GTO dash pieces that Joel made at the meet.
Kent White demonstrating metal finishing techniques on a P51 Mustang wing tip. This is an original tip, with the light hole already punched in the end. In other pictures you'll see the wing tip he made for the other side, that has yet to have the light hole installed.
John Forbes (co-host) firing up his hot rod to go to Michael Leed's for the shop tour. Note the neon spark plug wires, and the metal work. The pieces in the B pillar behind the door were made on his Pullmax, then patina'd to match the rest of the car. Yes, those are open headers on the street.
Old 06-11-2012, 08:55 PM
Default Blastolene Bros, Michael Leeds shop tour
Michael Leeds explaining to us mere mortals his latest creation. This is a Ranger air cooled, supercharged, 12 cylinder airplane motor, turned upside down and heads swapped side to side. On this roadster, the frame is the body, the body is the frame. There is one continious piece of metal from the front, around the back, and to the front. The front suspension is all flame cut individual pieces, welded together and ground to shape. The rear tires are Contenentals 445 50 23.5 if I recall correctly. He has driven it down the block, and identified some things he wants to work on. Air suspension. As I recall, somewhere around 700 Cu IN, 1000 foot pounds of torque.
Even Kent White was scratching his head.
Bertha, the one that started it all. You should see the burl wood dash in person.
Sollis
Kent White working with Mike (Red Barron), metal finishing the tank.
Old 06-11-2012, 09:48 PM
Default here are some of my pictures
here are some pictures of Ron Covell using a hammer form and a air hammer
Daniel Making a copper mask
Don did a great demo on the pullmax. He is the one that built the aluminum roadster pictured earlier
Ken trying out the Bammbamm
Diana and Kevin trying out Daniel's donut dolly
Anthony and Jesse welding up a crack on a 39 Ford front fender
Mike, Ken and Shawn bench racing
Joel's dash for his Ferrari
Red Baron's gas tank that he posted with the basket weave! very nice job
Shawn Marsh with his motor cylce tank that he started last year
here is Chris Gross and his new Dodge firewall made on Baileigh's hammer
Ron Covell and Kent White even bench race
Jaysin became the proud owner of a new magna brake
