Old 11-26-2016, 04:48 AM
shane_p shane_p is offline
Default weight of 42" edwards wheel
hi, i have purchased a 42" edwards wheel of the type shown in the picture. i need to transport this in a van and wondered if anyone knows the approximate weight ? many thanks Shane
Shane_p
Old 11-26-2016, 06:50 AM
hot rivet hot rivet is offline
somewhere between 650-750kg for that style of edwards
Paul
Old 11-26-2016, 07:29 AM
thanks Paul, van payload is 874 kg so should be ok ! cheers Shane
Shane_p
Old 11-26-2016, 03:38 PM
carl 180 carl 180 is offline
MetalShaper of the Month Oct. 2018
hi shane make sure it does not get lifted bye the shaft good luck they are not easy things to move
Carl
Old 11-26-2016, 03:52 PM
Be really careful if putting it in a van as the tie down points are not as strong as something like a flatbed. They are very unstable items when being moved and could easily topple in a van. Better be safe than sorry. Just my 2p worth.
Gareth Davies
Old 11-26-2016, 09:58 PM
RVen RVen is offline
Probably would be best to lay down. Not sure if it would fit in a van though.
Rob Ventura
Old 11-27-2016, 03:27 AM
Richard Lennard Richard Lennard is offline
For what it is worth.
When I collected mine, bolted it to two steels, width of van less breathing room.
Then decent ratchet straps from end of steels over the top of the wheel, ie triangulated and not using the van tie downs for the wheel itself, just the steels to the floor.
One thing is for certain, it cannot fall over, they crack and then they are dead!
"Everything is in the system, if it aint working, the system aint right"
Old 11-27-2016, 11:35 AM
If I were doing it, I would start dis assembling it. And get some stout lads to help.
CZ
Jerry Roy
Old 11-27-2016, 12:30 PM
thanks for the replies guys. planning to unbolt it off the stands and lay in down in the van, i can't risk it falling over !
Shane_p
