Old 11-09-2015, 10:56 PM
gdorn gdorn is offline
Originally Posted by idickers View Post
I applaud your ambition, that's a hard piece to make. Is that a BMW 2002? I had that similar piece rust out on my '02, and lucked into a parts car, where some quality time with a Sawzall resulted in a corner piece I could weld in as a replacement for my rust.
1977 E12 2.8 L-jetronic 4 speed manual
has a 83" e28 2.8 with a funny cam - screams to 6500 rpm
can drive it until I fix the rust - I also cracked the windscreen trying to get it out - thankfully I have 3 spare parts cars!
I have a 78 parts car - which if I have too could remove the panel - but I figure I might as well have a go at making one first - as the dark blue E28 is starting to show rust in the same location!
Gary Dorn
Perth Australia
Old 11-09-2015, 11:03 PM
Originally Posted by TRAMP View Post
I don't see why not. What tools do you have?
I have a - olive wood mallet, vice grips, wood stump, steel 2Lb hammer, chisels, henrob 2000 gas welder with gas, vice, 200mm long of 150UB14 ("I " beam, cordless drill and bits, hole saw kit, various files - mostly woodworking hand tools.
Gary Dorn
Perth Australia
Old 11-10-2015, 01:25 AM
Well I've had a go,- justing using pliers, clamp, piece of structural angle and universal beam.
First, I made a wood template so piece could be clamped and held whilst I bent first lip with pliers - progressively bending from edge to middle. This first bending tended to be a bit straight, so I hammered the middle and ends a fair bit on the the angle to create the curve.
With a bit of more flaming, bending then hammering (hammering on the top edge of the angle) I managed to manipulate the steel to bend along the desired line.
Using a clamp to fix the piece to the angle, I was then able to slowly bend the sheet for the 2nd lip with the piers - starting at ends and moving to the middle progressively, hammering at times to straighten out the kinks.
I did the same thing on the other side
Again clamping to a Universal beam flange, I was able to bend up the last lip - then hammered it flat(ish)
For a novice first try - not bad - need a far bit of planishing, plus I got the dimension slightly too large.
Gary Dorn
Perth Australia
Old 11-10-2015, 03:32 AM
Often ends up too large if you don't take off the material thickness with each bend depending on which direction it is going.
Old 11-10-2015, 10:48 AM
Gary before you start bending the piece measure it's width and then rite down the measurement from the edge each time you make a bend. That way when the sample piece is done you can find out which of the bends has to be moved to get the desired result.
Jere
Old 11-11-2015, 04:07 AM
pistol pistol is offline
Hi gary if you can wait to just after Christmas you can come and use my new bead roller.
cheers paul
Paul
Old 12-13-2015, 05:45 PM
Payupv8 Payupv8 is offline
Could you explain alittle more because I have a hard time with this also when I do multiple bends in a piece sometimes my pieces either come out to long or to short, understanding this and doing some practice would keep me from making as much scrap.
Eric Crafton
Old 12-14-2015, 08:04 AM
If you read up on "bend allowances" you'll get an idea of why you're getting results different than what you expect.
With some understanding of what happens "during" a bend, it's pretty easy to "repeat" within 0.020 on a brake. Same principles apply to any forming by bend.
regards
marc
Marc
Old 12-14-2015, 06:13 PM
Can I just subtract the material thickness from each bend?
Eric Crafton
Old 12-14-2015, 07:05 PM
If you look on this page of my thread I cover it here.
http://www.allmetalshaping.com/showt...=12411&page=13
