Old 06-28-2011, 10:49 PM
bcross13 bcross13 is offline
Default Surface rust on a shear bed.
Anybody ever reomoved surface rust off of a shear bed? If so what did you use/ what type of method (sanding, wire wheel, etc.) Thanks.
Billy Cross
Old 06-29-2011, 12:15 AM
Rondo Rondo is offline
I use WD40 and a gray scotchbrite pad to keep the surface run off my machines. Spray it on and let it soak for a few minutes scrub and wipe.
Rondo
Rondo
Old 06-29-2011, 12:31 AM
Thanks. That was my plan not sure if anyone had tried anything else.
Billy Cross
Old 06-30-2011, 01:52 AM
G. Anderson's Avatar
G. Anderson G. Anderson is offline
Default Rust off a shear bed
I use WD40 and a red scotch brite, just a little more agressive that grey.
Remove rust, then wipe off and respray with WD, keeps the rust at bay
A shear bed does not have to be dead nuts flat.
Your Pal, Gary
Gary Anderson
Old 07-05-2011, 08:17 PM
I usually use MetalPrep 79 or etching wheel cleaner (for raw or machined Aluminum wheels) to wipe the surface rust off, followed by a ScotchBrite pad with some transmission fluid or WD40.
Andrew Slater
HANGAR 18 FABRICATION
Old 08-12-2011, 07:25 PM
RickWG's Avatar
RickWG RickWG is offline
I've used a DA sander...80-220 grit...
before
after
RickG.
Those who possess real knowledge are rare.
Those who can set that knowledge into motion in the physical world are rarer still.
The few who possess real knowledge and can set it into motion of their own hands are the rarest of all.
Old 08-13-2011, 07:13 AM
I know its off topic but I have got to say I love that drill press!. I use WD 40 and green scotchbright but being in England (the land of non stop rain) and a few hundred yards from the sea makes it hard to keep things that way for long.
