  #111
Old 08-28-2016, 12:05 PM
Bob Kolenda was down for the week and was VERY instrumental in bringing the speedster much closer to actually being a viable car. He did all the instrumentation, wiring, plumbing and detail fabrication to bring it to the point where we got the motor started on Saturday. The pictures loaded a little bit out of order. We spent the earlier part of the week visiting some local points of interest and acquiring the myriad of detailed parts that are needed when running down the check list that is at the end of a long project. many futtings, bolts, etc and the occasional hamburger required many trips, but on Saturday we finally got to 'light' this thing up. The motor had not been turned over in many months, so we had to 'lubricate' the cylinders. There was quite a bit of the lubricant still in the cylinders, and when it finally 'lit', it looked there was a familiar Australian metal shaper ( the one that uses a torch to shrink aluminum.... ) doing the work. This car has no muffler, and when it started, it belched flames and fire from the header, sending smoke throughout the shop and it is rumored that there is no worry about mosquitos for the rest of the summer here in York County, South Carolina. John Kluttz, a well known Model A engine builder, happened to arrive at the shop shortly prior to starting the motor, and minimized the time it may have taken to sort out any 'issues'. Because I had installed dual carbs, I had installed gauges to monitor vacuum and the small oil pressure among other gauges. Bob was very adept at mating the two carbs in a manner that we can accelerate them at the same time and choke them simultaneously, but we will have to adjust the GAV separately. It has been a long time since I have had this much fun. Many thanks to Bob Kolenda and Charles Camp.
Attachment 38633
The smile in this pic says it all.
Congrats Will.
Old 08-28-2016, 03:33 PM
Bob Kolenda was down for the week and was VERY instrumental in bringing the speedster much closer to actually being a viable car. He did all the instrumentation, wiring, plumbing and detail fabrication to bring it to the point where we got the motor started on Saturday. The pictures loaded a little bit out of order. We spent the earlier part of the week visiting some local points of interest and acquiring the myriad of detailed parts that are needed when running down the check list that is at the end of a long project. many futtings, bolts, etc and the occasional hamburger required many trips, but on Saturday we finally got to 'light' this thing up. The motor had not been turned over in many months, so we had to 'lubricate' the cylinders. There was quite a bit of the lubricant still in the cylinders, and when it finally 'lit', it looked there was a familiar Australian metal shaper ( the one that uses a torch to shrink aluminum.... ) doing the work. This car has no muffler, and when it started, it belched flames and fire from the header, sending smoke throughout the shop and it is rumored that there is no worry about mosquitos for the rest of the summer here in York County, South Carolina. John Kluttz, a well known Model A engine builder, happened to arrive at the shop shortly prior to starting the motor, and minimized the time it may have taken to sort out any 'issues'. Because I had installed dual carbs, I had installed gauges to monitor vacuum and the small oil pressure among other gauges. Bob was very adept at mating the two carbs in a manner that we can accelerate them at the same time and choke them simultaneously, but we will have to adjust the GAV separately. Because I had to lower the radiator to lower the nose, you can see that we had to make a 'jackshaft' to turn the fan. We cut a generator pulley and welded it to the water pump shaft to drive the fan mounted below the water pump. I cut another generator pullet to fit that shaft.It has been a long time since I have had this much fun. Many thanks to Bob Kolenda and Charles Camp.
Attachment 38619
Attachment 38620
Attachment 38621
Attachment 38622
Attachment 38623
Attachment 38624
Attachment 38625
Attachment 38626
Attachment 38627
Attachment 38628
Attachment 38629
Attachment 38630
Attachment 38631
Attachment 38632
Attachment 38633
Attachment 38634
Attachment 38635
Attachment 38636
Wow, such fun !!
Would have loved to have been there, Will.
Very nice dash.....
Old 08-28-2016, 04:34 PM
Congrats Will!!!!!!
Always fun to see a fresh engine come to life!!!
Hey can I borrow that car for a while we have a healthy crop of Mosquitos !!
Old 08-28-2016, 06:50 PM
outsider347 outsider347 is offline
Great to have GOOD friends !!!
Ed
"To Be or To Do" John Boyd
Old 08-29-2016, 05:44 AM
Congrats Will.
No quite the same smile Will had last Year when he saw me approaching the tail panel with the big torch I never seen any body going green in the face that quick.......
Old 08-29-2016, 07:17 AM
Thanks, guys. It is a fact that I have more great friends than anyone deserves, but I enjoy the heck out of each one as a treasure. Kent, it would have been that much better if you had been there, you would of had a chuckle at us all! Peter, believe me... I gave that a thought at that very moment as I looked at the flames and smoke..... Steve, you are more than welcome to come and get this for your own use. I will hook up the brakes after you return it. LOL!
Old 08-30-2016, 05:44 AM
This great getting it running. True milestone that.
Old 09-01-2016, 04:48 PM
onya onya is offline
Hello Will,
Nice work, given me jealous push to get mine up and running now.
Leigh,
Old 09-02-2016, 09:51 AM
Steve_Greenway's Avatar
Steve_Greenway Steve_Greenway is offline
Congratulations on getting it running Will!!
Steve Greenway
Old 09-02-2016, 11:02 PM
slobitz's Avatar
slobitz slobitz is offline
MetalShaper of the Month February 2021
Default Model A sprinter
Hi Will,
I am almost as lucky with friends as you are ! My gang love old race cars. Professor Karl beamer , one of the finest Gold leafers in the country does the painting and lettering. Len Deren mechanic and machinist, Pasco Umbriac does the heavy welding [ he does better than me } And my Aussie friend helps when he is in the country. John Loxton of Austrailia is in the car I do the fabricating and louvers. If I had to pay them I could never Have all the cars I have. The Cook bros from Ben Cook racing have always given me great help.
stan...............
