Old 09-23-2019, 10:22 AM
snedboy snedboy is offline
Default Building an English Wheel
I've been looking into kits and the one from Stakesy's seems to have everything I'd need.
https://www.stakesys.co.uk/english-w...r-kit-full-set
I'd be using a couple of lengths of I beam for the frame.
However looking on the bailiegh website I found this
https://www.baileighindustrial.co.uk/ew-15-uk
Made in China but good enough to carry the Baileigh name.
Does anyone have any experience of the stakesy kit or the Baileigh machine?
Paul
Old 09-24-2019, 04:22 PM
carl 180 carl 180 is offline
MetalShaper of the Month Oct. 2018
Hi paul i put a eastwood wheel for sale on here in classifieds may be of some intrest to you.
Carl
Old 09-24-2019, 08:56 PM
Fasteddie Fasteddie is offline
Longyard posted on here about the same wheel as the Bailey and is sold as a Grizzley. Search under English Wheel and Longyard.
He posted about how to modify and tune these up. I have one of these same wheels that was sold by Harbor Freight and these are real small.
Eddie
Old 09-24-2019, 09:08 PM
I am sorry, it is listed under Mini English wheel for $99.
Eddie
Old 09-24-2019, 10:32 PM
Paul, couple comments:
1 - The Stakley adjuster may be ok but I don't care for their frame design. Mounting the upper wheel on a stub axle on the end of the top frame means the stub axle is the weak link in the frame as far as deflection goes. A much better option is to put the upper wheel UNDER the top frame via a yoke. This transfers the load to the frame.
2- Ibeams are not good material for ewheel frames. The reason for this is that they have much less twist resistance than rectangular tubing. This means that under heavy pressure, the upper and lowers do not stay in vertical alignment. In severe cases, the upper wheel can 'flip flop' over the lower. This causes all kinds of issues in your panels.
Check out the ewheel building seminars. If you're going to invest the time, trouble, and expense of building an ewheel. You might as well build a good one. A bad ewheel is hard to use, hard to master, and produces work slowly.
Old 09-25-2019, 01:39 AM
I see what you mean about the top wheel. That does seem like an odd choice. As for the I beams I was thinking of boxing the finished frame with 2mm sheet (14 gauge)
Paul
Old 09-25-2019, 02:45 AM
With the wrong wheel you will only do the wrong job or you will not want to use it. If you want to try what it does, get 2 bearings. Attach one screw on top and make a radius on the other.
of course use a fork that will push the lower radial bearing. It doesn't have to be complicated.
You will immediately see what you need. That bad wheel is for anger.
2mm is low.
Old 09-27-2019, 10:02 AM
Joe Andrews's Avatar
Joe Andrews Joe Andrews is offline
Default English wheel kits
Were still making the complete sets till the end of Dec. 2019. We will still stand behind our work and products. check out our web site www.hoosierprofiles.com
Joe Andrews
Hoosier Profiles Inc
213 N 1st St
Decatur IN, 46733
Phone 260-301-9034
Fax 260-724-2236
Old 09-27-2019, 02:41 PM
Sorry for me showing my forest technology.
Old 09-27-2019, 02:51 PM
Fabrycation's Avatar
Fabrycation Fabrycation is offline
MetalShaper of the Month April 2021
Default MetalAce U-Weld Kit
check out our MetalAce U-Weld Kit also. It has everything you need to build your own frame and get wheeling.
https://www.trick-tools.com/MetalAce...t_MA44F_UW_136
Brycen Smith- Metal Manipulation Specialist
www.prddesign.com prdbuild@gmail.com
Instagram: @fabrycatedmetal @project_ruptured_duck
Trick-Tools Master Fabricator Brycen@Trick-Tools.com Partners: Miller, Ford Performance, MetalAce, Dakota Digital
